1 - 2 of 2 Posts
I posted this in another persons Reply, but it is on the bottom & may not be read.
I believe this info will help those that work on their own rigs.
Take your needs to a bearing house(supplier) & they would be glad to help.....
Fluid compatabilaty, & sizing chart.
http://www.marcorubber.com/materialguide.htm
On the sizig chart, the numbers on the left are the universal part number for size on any material o-ring.
http://www.marcorubber.com/sizingchart.htm
Here is some good readig on O-rings. Explained in simple terms.
http://www.thesealman.com/pages/oring_handbook/pdf_files/epm_oring_handbook.pdf
Or, you can go to a bearing supply company & they will help you out.
We at Shell Oil use Applied Bearing & Motion Inc.
DangerousDan
Dangerous Dan,
This is actually more interesting than I had anticipated. Lots of good information if you can search it out.
I particularly liked the part about Simriz good to 615 degrees but not being recommended for:
Molten metals
Gaseous Alkali Metals
Halogenated Freons/Fluids
Uranium Hexafluoride
I next time I am in Iran, I'll have to ask which material they use in their Uranium Hexafluride Esfahan Conversion Facility, when they process uranium yellow cake into uranium hexafloride (UF6), for shipment to Natanz for enrichment.
1 - 2 of 2 Posts
