I bought a 2009 wheel and MT with 0 miles [triked new] and it comes with the oem air pressure sensor mounted inside the rim. I use the externally mounted Tire Guard TPSM when I run a CT.
Question #1 can I still use the Tire Guard with the oem setup in place?
#2 can the internal part of the oem sensor be removed and will the valve stem remain functional and in place, Or do I need to replace the oem valve stem with an aftermarket valve stem once I remove the internal part of the oem pressure monitor?:shrug:
thanks for any info
Andy
thanks for any info
Andy
