1 - 9 of 9 Posts
Thought I'd share a couple of lessons from my 4k mile service I did yesterday (6MT):
Fred's video mentions a requirement to be on the side stand. I hadn't seen that anywhere. More to follow on that.
  • Start on the center stand.
  • Remove drain plug.
  • Remove filter. I had a filter cap from my FJR that worked just fine. You can buy them at any auto parts store, no fancy Honda specific one required.
  • Clean all surfaces.
  • Prime filter and install.
  • Move drain pain and replace with a small container, rag or some paper towels.
  • Put bike on side stand and watch way more oil than you think should pour out. I really didn't think much would come out. I was wrong.
  • Put back on center stand, clean surface, replace bolt with new crush washer.
  • Fill oil with all 4 quarts.
  • Check levels according to procedure in owners manual and see a nearly, but not over-full reading.
  • You don't have to remove the side cylinder head cover to see the breather tube. It's a clear purple-ish. Mine was empty. I imagine removal will be necessary to drain it if needed.
Derby, Thanks for your post! Did you use Honda filter PN:
15410-MFJ-D01
Craig
15410-MFJ-D01
Craig
Not sure, honestly. I went to the dealer and bought the filter from them. It was the same as the factory-installed one as far as I could tell (which had no numbers on it that I could find).
The original washer will last you dozens of oil changes if you don't overtorque the drain bolt.
That washer isn't really a crush washer at all.
If you crush it, you've way overtightened it.
1 - 9 of 9 Posts
