Hi. I did my first oil change yesterday (2506 miles) including oil filter and DCT filter. I kept it on the center stand (can you actually change it when on the side stand?) so perhaps not all the oil drained out. I filled it with 4.9 quarts and checked it twice - once after a 30 minute ride and once after it sat for a few hours and did a 5 minute idle warmup. Both checks the bike sat 3 minutes to settle. The oil reading was toward the bottom of the dip stick so I added the remainder of the 5th quart - so 5 quarts in total. Still only half way up (if I'm reading it right!!).
I have Three marks on my dipstick (see picture). You can see where my oil is after adding 5 full quarts and checking after 5 minute idle. Question:
1) what is the min and max indicators - between 2 & 3 (my assumption)? between 1 & 3? between 1& 2?
2) my oil is reading halfway between 2&3 and 3/4 between 1&3 - Am I way over full? Perfect? Need to top off a bit more?
3) If I'm overfull - do I really need to drain some out or is it ok to ride?
Thanks much!! Rob
Thanks much!! Rob
