Having never changed the oil on my trike I got the impulse to do it. Watched the Cruiseman video a couple of time (Thanks Cruiseman)
Went to Wallyworld and got the necessary goodies. Laid down a plastic sheet on my garage floor.
Engine was hot so took off the front part of the belly pan, and with a 17mm socket drained the oil. Had a bit of a tussle removing the filter, but it came off and oil drained into the drain pan. I let it drain for about 20 minutes and replaced the filter. Even remembered to wet the seal with a finger tip of of oil as explained. Put a new crush washer on the bolt and could not find the 17mm socket. Looked everywhere.
Replaced the oil without spilling any.
So, I used a 17mm open end wrench. NOT THE SAME as using the 17mm socket. Could not get the torque with the open ended wrench.
Did not replace the belly pan as I was not sure if the bolt was sufficiently tight. I put down some newspapers and checked it a hour later and there were oil drops on the paper. Oh Crap. Looked for the 17mm socket and I could not find it. Put the drain pan under the engine and left it there overnight In the morning I found maybe 5 drops in the pan, but knew it was not right. Ran it to the dealership and a wrencher told me the bolt was finger tight. He tightened it, checked the oil filter. (that was good) and replaced the belly pan. No charge other than a $20.00 tip.
Now for the good part I took the old oil with only 6200 miles on it to dump it this morning at a friends car center. I was interested how clean/dirty the used oil was and it was very clean. I put some on my thump with a peice of newspaper between the thumb and the oil and could read the print on the paper.
Don't want to start a oil war, but this is regular 10W-40 non-synthetic oil and it did not look half-used.
BTW, I found the 17mm socket. Point of story is you need a socket to properly tighten the drain plug. A box end wrench will not work. Or, it did not for me.
