1 - 20 of 40 Posts
Bought the bike on Saturday May 3, 2014.
Air Filter was replaced at 30,000 by previous owner.
Change the oil and filter, today May 13, 2014
At 36,000 Miles
Used synthetic Mobil 1 10w 40.
Also disabled the anti dive vale; used a nickel.
Hitch
Added a Kuryakyn hitch to the bike, today Friday June 27, 2014 39,700 miles in the odometer.
Oil Change
Changed the oil at 40,100 miles in the odometer. Rotella T6 Full Synthetic 5W-40
I too am using the same hitch you have. But do yourself a BIG favor and use the Blue loc tight on your crash guards bolts I just came back from Wing Ding and lost one of my guard bolts so double check them.
Discussion Starter #8
Thanks for the heads up. I'll double check the bolts.
Discussion Starter #10
Fron Tire - Front Brake Pads
Yesterday, 08-22-14, installed new front tire and OEM brake pads. Bike has approx. 42,700 in the odometer.
Discussion Starter #11
09-14-14 Changed oil and filter (Rotella T6). Approximately 43,800 miles in the odometer. Also changed clutch fluid and final gear oil.
Discussion Starter #14
New rear tire and oil and filter change at 47,900 miles in the odometer.
10,900 miles on replaced tire.
Discussion Starter #15
Engine and Rear Oil Change
July 28, 2015. Engine oil change; Rotella T6. Also change the Rear; Mobil Synthetic used. Mileage is about 51,000 miles.
Discussion Starter #19
Oil, Filter and Rear Oil Change
June 11, 2016. Rear differential, engine oil and filter change at 58,000 miles.
1 - 20 of 40 Posts
