We like to fret. Fretting is the whole point of an oil (or oil filter) thread.The oil filter type speccified for a given product takes the resistance of that filter into consideration. Even when the filter is at the end of the specified filter change interval. Don't fret.
We like to fret. Fretting is the whole point of an oil (or filter) thread.
OK. Carry on.We like to fret. Fretting is the whole point of an oil (or filter) thread.
"Fret" is an excellent word.OK. Carry on.
I just bought 2 gallons of GN4 10w30, and two oil filters from my local dealer.I always change the filter when I change oil but it's 2022, OEM Honda filters are more like $17-$18 and up, way up depending where you get them...
Thank you!Ya know,
I have never, EVER understood logically, the reason a manufacturer authorizes an oil filter change EVERY OTHER TIME the oil is changed. Now, I have to figure that most manufacturers kind-a know what they're doing in terms of engine design, maintenance, oil types/quanity/quality/weight/and more so, to say that you only need to change the filter every other time, apparently is just fine with them. It just doesn't sit well with me. I mean, you're dumping out 90% of the old used oil with whatever kinds of contaminates that are carried out with that oil.
But, you're leaving in a DIRTY FILTER with some of the same contaminates etc. in it. Yes, the filter is supposed to FILTER out all those but whether or not it does, I don't have a clue. So, with all that being said, it just makes sense to me to spend the $4.50-$6.00 or so on a new filter every single oil change.
Scott
Quotes not intended as shots at anyone, just used as examples.ALL your doing is replacing all thethat the first filter removed from your old oil...........I thought that was the reason for an oil change in the first place...
Ligic only has a place in a minor part of the equation. The primary and illogical factor is the carbon/pollution "footprint" concept, what is it called? CAFE? Now, I have an application were I think I have logically decided to change oil keeping same filter with two pieces of my land management equipment; a Ventrac 4700Z tractor and a John Deere 650 CUT. It gets way hot here in the summer and way cold in the Winter. Winter chores for these machines iare relatively light, usually 20 to 25 hours each in snow removal or fire wood processing. New filters fitted at end of fall season and oil chnanged to very light oil weights such as 0-30 expecting starts at below 0 F temps on occasjion. The OCI on either machine is 200 hours. I drain the light oil in spring and also remove and let the filter drain as much as possible, then use the proper grade of oil for hot and heavy long day use. I then change all when the 200 hour OCI (total per last fall) occurs. Logical? I tink so. I have cut open filters on all of my stuff, incuding the Wing, and have never seen any condition even close to being loaded -- typically pretty clean except the diesel CUT's filter is blackened. The DCT filter on the 2018 Wing was very nasty the fisrt change, but near pristine since. But, on the motorcycle I change all every OCI. Hmmm, come to think of it, the Wing is the least expensive of those three machines... go figure???Ya know,
Scott
Part of whats being discussed is that the newer Honda service manual recommends a different schedule for oil filter changes. Also notice the filters have no specific change based on "date" because there is no consumable (oil additives deteriorate over time) so to be accurate the recommendation for filters is based on mileage alone....
My manual recommends oil changes using an OEM filter and Honda GN4 oil, every 8,00 miles with a new filter every time,...I am no expert on oil changes or oil filter science or their construction but my manual at least says to change the filter with every oil change....
There's something synthetic about this post.I drain my oil every night. I bring it in the hose to keep it warm.
I use three drops of Dawn per 2 cups of Hot water, to rinse out the Filter.
I Got tired of shaking out the water. I found the washer spin cycle saves my arm from cramping up, with the shaking method.
I haven't bought new oil or fiters in 12 years,
Bike likes the warm oil too. Shifts real smooth, like it's a Automatic.![]()
I had already acknowledged earlier in my post that other manuals could be different.Part of whats being discussed is that the newer Honda service manual recommends a different schedule for oil filter changes. Also notice the filters have no specific change based on "date" because there is no consumable (oil additives deteriorate over time) so to be accurate the recommendation for filters is based on mileage alone.
of course the info given in manuals covering other years may be different
The sentiment expressed a few times in this thread that I am curious about though if I am understanding the arguments correctly, is the one saying essentially that changing the filter every other time reintroduces contaminates that were trapped in the existing filter back into the new oil.
