Removed the rear wheel to fit a new tyre to other day and checked the park brake pads while i was in there and found the outer pad had gone Metal on Metal no big deal no disc damage remove the caliper and then found the real problem Both slides were sized all most solid dismantled cleaned and degreased the slides which had NO lube on them from the factory new pads i had in stock adjusted and back on the road.
SO CHECK THE CALIPER SLIDES PEOPLE
