I need the part number for the antenna mast only for the CB atenna for my 2001. I can find the radio number, but the CB antenna is difffernt and all I can find is the part number for the assembly
thanks
John Wodarski
No one sells "Just the Mast",that I have found.But if I was was to buy a complete CB antenna.I'd buy the Hondaline Antenna.
The Add On antenna has a cheap base that will get loose at the Rivet on the top of the base.
You can tell the hondaline becaise it's flush like the radio antenna base.
The aftermarket CB antenna base rivet has a mushroom head on both sides that stick out.
That rivet gets loose in time from the mast bouncing around.I know I replaced two bases and then found that the hondaline radio base would work on the CB side too.it's been three years now and it's still hasn't come loose like the cheap aftermarket brand had from wingstuff.
