1 - 11 of 10 Posts
Has anybody used the pathfinder led headlight amazon has them for 100.00 ?
Yes, and I like them. If you do get them, get some 16" inch needle nose pliers from Harbor Fright as it makes install easier on the high beams. YMMV
I have 2 pairs installed for high and low beam operation. they are WHITE lights. They may cast light a little farther down the road, but there is increased clarity of objects in the light beam.
We have them on our 2010 Goldwing Trike. We had our servicing dealer install them when he did our air filter. We bought them from him and not Amazon. Have both high and low beam.
My bet would be that Pathfinder imports them from China.
So your saying Pathfinder is it's own company? In other words, Pathfinder is NOT just the name of a product line, but the name of the actual company, yes?
Any Pathfinder product I've purchased came from SoCal Moto Gear (SoCalMotoGear.com - Professional Grade Motorcycle Lighting - Plug N Play - "Riding at night has never been brighter!"). I'm not sure if the Pathfinder brand is theirs, if they manufacture them, or it's just their design and they're made off shore.
Regarding installation, I just installed both high and low beams on my 2010; the low beams are really easy to get to. As far as high beams, I did mine in conjunction with an air filter this winter, the high beams were actually easier to get to than the low beams with the top shelter off. If you can hold off on the high beams until you have to pull the shelter, it makes things much easier. Another thing to consider is that you have to secure the inline driver units. I zip-tied mine to the faring framework, and it was a chore; a lot of working by feel only because you can't see what you're doing.
Be careful when zipping to the fairing frame. Put in the wrong place the forks will hit them enlarging your turning radius substantially. After learning the hard way, I used foam tape and attached them to the fairing.
Yea, I learned the hard way when I had HID headlights installed on my 1500 at Americade; I couldn't even lock my forks and had to have them move the driver boxes. I ended up reinstalling them myself when I got home; not a big fan of rally installers. On the 1800, I jacked the front end up a bit so I could swing the handlebars and mounted the drivers up out of the way of any fork movement.
I just did this install today on my '16.
I removed the highest push pins underneath the fairing and stuffed the driver and wiring up in there, then reinstalled the push pins. Appears to be out of the way of everything, plus it made for a clean installation. Did not need any adhesive.
1 - 11 of 10 Posts
