Does anyone know if anyone makes a plug-n-play brake light modulator that will work on a 2013 Goldwing with a replacement LED run ,brake, turn signal installed. The Modulator can either be for the spoiler light or Trunk lights or both I have not had any success finding anything.
Still Looking
I was hoping to get a device that adds the running light feature to the factory led spoiler, as well as the brake light modulator.
I will keep looking, Thanks
Tommy
Pulsating Brake Light Controller
Check Kuryakyn.com part 908. This taps in to the green wire with red tracer under the seat. The instructions with it are pretty clear. Works good.
If I remember correctly there are two connectors under the seat. One under the passenger (standard brakes) and another under the driver right cheek (trunk lid wing). Splice into the one you want to modulate or build a jumper and splice both connectors thru the modulator for the best brake modulator effect.
Electricalconnection.com makes the spoiler run brake harness. (Hon GL18 Spoiler Run/Brake Harness, 2012+)
Several places carry these parts. Google is your friend.
