1 - 9 of 9 Posts
Wanted to say Hello to everyone here. Just bought my Wing 2 weeks ago and loving it. Would like to ask, I have installed a GPS after making a mount for the dash and was wondering were I can find 12 volts around the dash area to hook it up. I don't have a service manual and have not taken any dash pieces loose yet to know how. I am curious if there is a 12 volt connector maybe under one of the pockets that could be used?
Thanks and hope to be around this board for awhile. I just bought the 06 Wing and also have an 04 VTX bought new in 04.
Again thanks for your help.
Lee
Ran mine to the battery. Didn't want it work off of ignition.
Mine is wired through the 12v power supply under the front left pocket. I'd rather have it wired through the ignition so I don't have to remember to turn the GPS on and off every time I start the bike.
Mine is wired to accessory.
My GPS has a built in battery. If I want to keep it running while I am stopped I just have to press any button within 30 seconds.
Even so, reboot after something like refueling only takes a few seconds and it goes right back to the route I programmed.
If you don't have a battery built in, then you have to make your decision for how you want it to operate.
Discussion Starter · #9 ·
Mine is also like yours and I can choose to keep it going after the power has been removed. I want to thank all the suggestions and will get to it today. Its great to be able to have such information available at the touch of a button, just like it was on the other VTX board.
Thanks again for the quick help.
GWLee
1 - 9 of 9 Posts
