Status
Not open for further replies.
1 - 12 of 12 Posts
SOLD PENDING PAYMENT.....This high power Off Road LED light , made for Probox tops by VisionX .
this is a new light from a store display, these sell for $120.
$60 shipped.
It is a spot beam. The multifaceted reflector with the shield over the bulb is what concentrates the beam. Floods have smooth reflectors and no shield over the bulb..
Well, I'm wrong ,it's just the opposite of what I thought. Makes the light a flood light..
$60 shipped.
Can you throw a tape measure along side it , I may want it if it's small enough .
Any idea the candlepower .
It is two 10 watt LEDs it is 4 5/8" wide by 2 3/4" height of lamp without bracket. with bracket it stands about 3 1/2"
and it is 3" deep without the bracket and about 3 1/4" with. the bracket can be slide around and or flipped over to whatever mounting is needed.
  • LED Power: 20 W
  • Brightness: 1,720 Lumens
  • Operating Voltage: 10-30 V
  • IP Rating: IP68
  • (2) 10 W high intensity CREE LEDs
  • Current Draw: 1.75 A @ 12 V
  • Color Temperature: 6,000 K
  • Housing: Powder coated aluminum
  • Lens: Shatterproof polycarbonate
  • Mounting Bracket: Powder coated
  • Oversized heat sink with integrated thermal management
  • Beam Pattern: 90° flood
  • Lifetime: 50,000+ hours
Your on it alrighty . I will have to go out in the morning to measure project I. Am working on . Thanks for speedy reply .
Oh, and the wires coming off from it are a few inches shy of 3 feet.
Discussion Starter · #9 ·
OK, let me know!
Just a bit longer than I need. Good luck with sale anyway.
Discussion Starter · #12 ·
1 - 12 of 12 Posts
Status
