Here are the symptoms:
1. Faint (but annoying) background "clicking" noise when Intercom is turned on and rear helmet is plugged in.
2. Occurs regardless of radio setting (FM/AM/AUX), even if MUTE is selected.
3. Only occurs when rear plug is used, if you unplug the rear headset, clicking goes away. Also, if you turn off the Intercom, clicking goes away, even with the rear headset plugged in.
4. I tried 2 headsets on rear plug and still get the clicking, this eliminates the possibility of a problem with the headset.
5. Clicking is present in the front and rear headsets.
Has anyone else tested this or experienced this problem. I wonder if this is a defect in the '07 sound system.
This is a continual clicking sound, not intermittent. I spoke with a couple of dealers and they say they are not familiar with the problem but that it should be covered on warranty. Also, if it was ABS wouldn't it occur even if the rear headset were unplugged?
Is it a clicking sound or like a slight beep? Do a serach for abs sounds, clicking or beeping and you will probaly find your answer!
