1 - 12 of 12 Posts
15 weight is what Progressive told me. set at 5.5"
That's not what Progressive Suspension told me.....................
They (Larry Longely) said that on the GL1500 to use 15wt...............but on the stiffer GL1800 to stick with 10wt oil with the Progressive springs.
Author: Larry/Progressive
Date: 12/2/2003 10:36 pm PST
For the 1800 Wing I would recommend 10 wgt fork oil, any good fork oil is ok, we usually use Motul.
I used Amsoil medium "shock therapy" (10wt)
Chard Member
They used 10weight in mine. The springs will make the frt much stiffer. I didn't want to add to that stiffness with a heavier oil. Glad I didn't.
At 25,000 my front OEM springs were gone. For the first few thousand after the Progressives were installed I thought my teeth would jar out. Very rough at first, now I love them after about 6,000 miles.
oil weight
i have always used the eigt of the loaded bike for deciding what wieght of oil to use .i am 200 lbs and my wife is less and i tried useing the 15wt and iot was too stiff i would recomend if you weight more than use loaded you might want to use the 15 if not it is always good to stick with what honda says...just my two cents..
fork oil
If i remember correctly, i think that phil flack rally services installed 15/20 weight fork oil in my wing. I also replaced the rear spring to progressive as well. My wing rides smooth, no problems, no dragging.
JD :biker:
1 - 12 of 12 Posts
