1 - 17 of 17 Posts
It is so easy to change the erl on a Wing. Why would you want to bother with a pump?
Besides all the junk, if ever there is any, lies in the pan.
I know that I am not interested.
Bulldog
Legend in His Own Mind
Bulldog
Dawg,
I was thinking he might have overfilled it when he changed the oil and wanted to remove a little, maybe not.
When my bike came home the first time it was overfilled. I used a syringe and 1/4" tubing to drain the excess. Once the siphon is started you can drain as much as needed. For changes I use the drain plug.
I have one mounted on a 3 gallon bucket and runs off the battery. Works great for my inboard and other things as well. It may keep you from having to buy more of those expensive crushed washers.....
You will save a ton of money by not having to buy crush washers. You will not have to worry about messing up the threads on the drain plug.
By the way, any one know how often your supposed to change that dang ol crush washer ?? I have not put a new on my bike yet, but the bike is pretty new at age 6 yrs and almost 210,000 miles.
JMHO 8)
JMHO 8)
Be careful there Tom,
At this point, the engine case has probably warped itself to match
the distorted shape of your excessively abused crush washer. :wink:
Any attempt to install a new crush washer is therefore strongly discouraged
as it can transfer severe stress to the aluminum frame,
which has been shown to cause frame cracking. :lol: :lol: :lol:
DC
JMHO 8)
My '06 manual says very oil change but I think that is so they can sell crush washers.
Q
Has anyone ever tried using a pump to remove the oil from their Wing instead of using the oil drain plug?
There has to be a harder way. How about a pump with the hose run in thru the gas tank? And to make it more interesting, change the oil with the engine running. Or maybe turn the bike upside down and vacuum it out the vent?
Using the drain plug for what it was designed is simple chicken and unimaginative.
DC
WHAT!!!!!!!! :22yikes:
Chard Member
I had a '01 that would suck all the oil out of the crankcase and send it through the intake within a few miles. I didn't realize the benefits at the time! LOL....
Why change the Oil? What's the benefit, it's just more Expense!
CHANGING THE OIL
LOTS CHEAPER THEN BUYING A NEW MOTOR
Sometimes I wonder. I know somebody who has a landscape company and he brags about going 60,000 miles between oil changes. His vehicles seem to get about as many miles as anybody elses.
If I tried it I would be rebuilding my engine.
Q
1 - 17 of 17 Posts
