I have searched, looked at the manual and have a set of DVD's on order.
My questions are:
1. Those that used the cement anchor to pull the bearings, what did you use to pull against the cement anchor?
2. If I get the All Balls, do I need to pack them with grease or are they already to be installed?
I have a 2010 Wing, with just over 14,000 miles. When I had a Dunlop E3 installed, I had vibration in the handlebars after being balanced. Took it back for balancing again and the tech noticed that when he spun the wheel, a regular bump could be felt through the balancing rod that goes through the axle. When I removed the wheel initially, the wheel turned sideways on me and dropped down. It was a struggle for me to get it propery aligned to get the axle out. The second time, I knew what to expect and no problem. Anyway, I am thinking I may have damaged a wheel bearing.
This is something I did and thus do not want to deal with warranty since it is not a defect. Even if it were, I would rather handle myself for as inexpensive as the repair will be.
My questions are:
