1 - 4 of 4 Posts
Yup, finally dun it. Fell over on another bike.
Now my right mirror is broken at the swivel joint.
I can't seem to locate instructions on removing the broken pieces and replacing it all with the new assembly. It's all taped up now, so I can't look under all that tape.
Anyone got instructions on R&R Right Side mirror? (or either one as they must both be the same.)
I'd like to be ready and have the full idea and pictures if possible in mind before the new mirror gets here.
Pull back the rubber boot between the mirror housing and the fairing and you will see 3 screws that hold it on, remove them and the entire mirror housing will come off, The mirrors pivot back and forth so you can get to the screws.
Before you remove the screws, stuff a rag below them or you may lose one in the abyss (never to be seen again:22yikes:).
1 - 4 of 4 Posts
