Hi all, I'm putting gold valve in my forks of my 06 wing. On the left side fork with damper rod you need to drill holes. they show 2 holes already in it and want you to drill 4 more. Mine already has 4 holes around the bottom on the same height around the rod at the bottom. They say drill 2 up 10 mm and 90 deg.around and 2 more up 10mm and 90 deg. around from the first ones. With mine already having 4 holes how many and where should I drill holes. Also I don't have rebound holes like they show in the damper rod.:shrug: What should I do. Thanks
