I know, ride the speed limit and you will never need it ! BUT, I just want some extra protection when the testosterone kicks in on that lonely quiet road.
Now that being said, I want to purchase a Valentine 1 detector and mount it to the outer portion of the handlebars, as it has a rear antenna also.
Where can I find a mount, hopefully even a locking mount, to achieve this ? I know if anybody has the right answer, it will be you "gaget freak" GlodWingers ! Thanks for your help, Craig
Legend in His Own Mind
At one time I ran a detection unit that utilized external fore and aft lazer modules. Screwed one up under the fairing and double lock velcroed the rear under the trunk. If I've misread you, a self contained R/D can mount easiest via ram mount.
Yep, a RAM mount is an excellent choice. Check out CycleGadgets.com as well. Scroll down to the Radar Detector section and you can see what is available: http://www.cyclegadgets.com/Products/RAM/
Cycle Gadgets has an excellent RAM mount for the V-1 that I haven't seen elsewhere. The V-1 is attached via a magnet to the shelf and a remote adapter can be affixed to the top of the V-1 with Velcro. It makes a neat installation. I attached mine to the clutch master cylinder bracket on the left handle bar so it can "see" behind me.
You guys are great, thanks so much for the excellent advice. Craig
