a friends radio shows stations but can't get any sound, checked fuses, un-pluged, and re-plugged the main connection, still nothing, anyone have any ideas. Thanks
Did both, I've got a little radio sound through headsets if I put the volumn up to 30, this bike has a c.d. unit installed but hasn't been used. Got me stumped unless the radio has gone badPull the fuse labeled "battery" wait a few minutes, reinstall it and try it again. Also check the mute button.
Mute button?Did both, I've got a little radio sound through headsets if I put the volumn up to 30, this bike has a c.d. unit installed but hasn't been used. Got me stumped unless the radio has gone bad
on the left handlebar switchbox.Mute button?
pushing the mute button mutes in the headset, so I know its right. have to set volumn full open to hear thoughIf you can hear a little noise inthe headsets, then pus hthe "mute" button and see if you notice a change in the noise you can hear. If the noise is muted even more then your mute button was in the correct position. If it gets louder, it may be fixed. this is the mute button onthe left bar. make sure your on fm 1 and tuned to a known working station.
no sound at all in the speakers!the sound is low thru the headsets, how is it thru the speakers?
