1 - 3 of 3 Posts
I have a 2006 GL1800. When I am riding I seem to get only one station on FM (101.5) and only 1210 on AM. Sitting in the garage I will get many stations, but not when I am on the road.
Gordon
When you tune the radio to other frequencies when riding what do you hear static? If you hear static you have a power supply problem.
Antennae plugs....
Make sure the antennae is plugged in at the radio and under the seat. Also make sure the ground strap inside the trunk is not broken. It could be that the garage is being a signal collector letting the antennae less radio pick up the signals. If you have ever had an old hand-held AM/FM that had the antennae broken off and you pick it up not touching the antennae stub and poof, music; but put it down and static.......then you know what scenario I am describing.
1 - 3 of 3 Posts
