Symptoms...
Bike.
2008 Air Bag
80,000 + miles
Three weeks ago my radio would not come on when I turned the key on or after I started the bike???
The indicator for the radio in the GPS window was not showing up either...
Figured maybe a fuse???
Checked fuse... Not that...
After three minutes of riding the radio came on, but it did not blare out it kinda faded in very slowly until it got up the volume I had set it for the day before...
When the radio came on the radio indicator in the GPS window had reappeared and all works just fine as if nothing ever happened...
So I figured it must be a loose connection...
I tried hitting as many pot holes as I could find to see if I could knock something loose but nothing, it kept playing just fine...
An hour later I stopped for gas, when I turned the bike back on, no radio again, this time it started the same way, faded in slowly, only about ten minutes later...
When I got home I check all connections I could find nothing loose...
Since then every time I turn off my bike (one minute or over night) the radio does the same way, will not come on until riding for a wile, the only exception of the time that it takes to fade in, any where from one minute to twenty five minutes to come on...
Yesterday it stopped coming on all together and has not been back on since...
Can't be fuze or connections, I checked them, all OK...
Any information as to what is causing this???
Pushing any and all buttons (AM, FM, CD, CB) makes no difference at all
The radio,
amp,
switch,
a relay somewhere???
Bike.
2008 Air Bag
80,000 + miles
The radio,
amp,
switch,
