Just wanted to let all you guys and gals wondering if raking you trike is really worth it that it is!!! I'm here to tell you it's worth every cent and if you do it yourself like I did then it's worth the hours invested.
I bought two GL1800 4.5 degree kits from Adventure Motorsports and installed one kit on a friend's '05 GL1800 last week. he was extremely pleased with the outcome.
Yesterday after our morning ride I started in on my '06. In addition to the rake kit I also rebuilt the forks, installed progressive springs and replaced the Bridgestone 709 with a BT45 (reverse rotation). Time wise I spent about six hours yesterday and a little over seven hours today. After I got things together I took a quick check ride to see if I was as happy as my friend. YUP -- HAPPY is a good word...
Here's the differences I found. I really tried to be objective and even looked for negative changes which I did not find.
1. Steering effort was so much improved even I couldn't believe it.
2. Cornering is much quicker and easy to do full 90 degree turns (no more lazy corners)
3. Once out on the highway I found it easier to maintain smooth and straight travel.
4. The wind didn't blow me around as much and it took almost no effort to correct when it did.
5. Even though I installed stiffer front springs, the added 3 inch wheel base made the ride smoother.
