I found the number you need, on the Direct Line site it's on the fiche for the primary drive gear, number 2 on the drawing, Gear Assembly #13430-MCA-780
Steve, Yes I do. And all other gaskets, O rings, etc that may be required.
Thank for your reply. galewing
PS: Under what heading is the alt. drive found? galewing
then in the drop down list select Rear Case for the rear crankcase cover and related gaskets etc.
You will also need a clutch cover gasket which is on the fiche for the Clutch Cover.
Steve, I found it. (primary drive gear) And I thought I looked at every
heading?
Thank you,Steve. And thank you to our sponser,Honda Direct Line.
To all a MERRY CHRISTMAS and a happy new year. galewing
