1 - 16 of 16 Posts
2021 Goldwing DCT non tour
Input device Automotive design Font Personal protective equipment Carmine
Vehicle registration plate Automotive tail & brake light Vehicle Automotive lighting Light
I am looking into adding some additional rear lights to my 2021 non tour. I have been looking at both the Goldstrike and Kuryakyn rear panel filler lights. These are both non drill, run/brake/turn signals that are plug n play with the correct wiring harness. Any thoughts/opinion's of those of you that have any of these. Worth the money? Do they work? Bright?
Thank you for everyone's input.
I haven't done an A-B comparison of the lights however I can tell you overall Goldstrike makes a better product and has a more responsive customer service.
2018 Goldwing Tour DCT
· Premium Member
I don’t like the led lights that are made up of many small dots as they are very hard to see in the daylight. On some you can’t see the turn signals Or the running lights except close up.
For those two lights...for me it is Dots (Goldstrike) vs OEM (kinda) look (Kury)....I don't like LED dots. Comes down to personal taste.
Like @iride4u, I have and prefer (for the same reasons) the Pathfinder Rear Saddlebag lights over both Goldstrike and Kury filler lights.
Also have the Goldstrike unlighted rear fender filler strips to cut down on dirt.
Installed the Pathfinder Rear Saddlebag Lights about a year ago, and could not be happier. Everyone in my riding group remarks about the conspicuity, and simple good looks. SoCal product quality is outstanding. As many have remarked, Mother Honda should have installed this type light straight from the factory.
Apologies battery not connected. When back together will send you bike-on photos. Putting Polk mm522's in front and new amp in saddlebag. The panel is not as bright as the kury brake lights or honda brake lights but does the job. If choosing, recommend kury brake lights first. Much brighter. Here is the rear kury pic and pics of my speaker upgrade attempt. My first thread hijack. The Polk's much greater built quality. Hope they fit. Note I am tapping into front speaker outs directly from radio. Run those to amp. Then new 16 gauge wire from amp to polks.
Hood Vehicle Automotive lighting Automotive tire Automotive design
Motor vehicle Automotive design Automotive tire Automotive exterior Automotive wheel system
Electrical wiring Computer hardware Audio equipment Cable Electrical supply
Motor vehicle Hood Vehicle Automotive design Automotive battery
Automotive tire Wheel Rim Motor vehicle Automotive wheel system
Motor vehicle Automotive tire Bumper Hood Automotive wheel system
Discussion Starter · #12 ·
The Kury brake lights you refer to are the up/down ones that are next to the license plate? They are brighter than the ones on the outside? Thank you very much for your input
1 - 16 of 16 Posts
