I want to replace the rear red LEDs on my 2015 GL1800. Ive already done the breaklights and purchased LEDs 7443 from Amazon (alla Lighting).
The issue is that the LEDs are too long, I cannot fit the bulb housing back in because the LEDs bump up against the plastic lens inside.
I have been looking on Amazon for different ones, but most of them dont tell you the measurements or if they do, I cant tell whether its the entire bulb length from end to end.
In addition, I gave up on replacing the turn signal LEDs in the rear for now becuase the bulbs I bought (same company, Alla Lighting) do not stick into the housing tightly.. they're loose and would fall out.. not to mention that the rapid flash thing is beyond my technical ability right now.
So my question, does anyone have any recommendations for RED LEDs for the rear that will fit (and not fall out) and same for the amber turn signal lights.
Thanks in advance
Thanks in advance
