1 - 11 of 11 Posts
I just purchased a new to me rear wheel and rotor. I am looking to see what type of rotor bolts to get. I have looked online but am unable to find the part number to order. Any help is greatly appreciated. I am just getting mmy feet under me and getting the courage to do my own maintenance work.
Thanks Larry
Only 2 bolts hold the rear rotor on and they are Philips head.
you can order from the board sponsor part number
SCREW, FLAT (6X16) 90132-MCA-000​
Thanks for the help Guys. Your great and fast response. I will order from HAL as I like the service and pricing.
Larry
Thanks TravelinLite that helps alot.
Now begs the question:
How come an impact tool is needed to break loose a screw that is only tightened 6.5 ft-lb?
The same thing crossed my mind when I posted. The manual doesn't say anything about using any kind of thread lock, so I have to assume it is because the heat back there makes them hard to get out.:shrug:
I had to use a manual impact driver to get mine loose.
If you have never tried to loosen these Murgie without a hand impact it is almost impossible without damageing the heads and then there are real problems as the heads are countersunk.
1 - 11 of 11 Posts
