I have noticed that in the daytime, the turn signal indicator on my 2021 DCT is not very eye catching because it is surrounded by the red running light and the red brake light. I bought some Ebay lights that replace the filler at the bottom of the side bags right above the muffler. The Ebay listing specifically indicated that they were compatible with the 2021 DCT and would plug into to the 48000 harness for added lights. The fit was fine, but when I tested them, only the run and brake functions would work. I happen to have the Filler lights from Goldstrike with the 48000 harness. The yellow turn lights in those is washed out in the daylight as well. Those lights included a 48035 patch cable. When I connected the new bag lights to the Goldstrike patch cables, the turn indicator LEDs worked. My understanding is that the patch cable includes a circuit that uses power from the run light to drive the turn indicator LEDs because the 2021 and newer Goldwings have a lower power for the turn signal function. Goldstrike doesn't have the 48035 patch cables listed on the web site but you can call and order them for about $65.
I like the lights now that they are working. Needless to say, I think the Ebay product should be clear about the fact they don't provide turn indicator function without the patch cable. I hope this might help someone else.
