1 - 13 of 13 Posts
2010 Wing audio comfort package 70,000miles
I just did the first air filter change a few thousand miles ago. Some time after that I noticed that I had to raise the volume on the stereo. Then I noticed that there was nothing coming from the rear speakers. I set the balance to full rear and still nothing.
I am wondering if I missed a connection or need to clean one under the seat. I wiggled whatever connections I could find but still nothing. Where should I be checking??
thank you in advance
Gil
IronMan
If had seat off did you check connections under there ?
I took the seat off, disconnected and reconnected the plugs.
I will look for a white wire on the left side.
Thank you
On my 2010 I figured that the wires in the harness broke but just to check I plugged in another set of speakers and they worked fine. The stock ones were blown.
I have had to repair every single wire on the left side hinge on my 2010 and several on the right. I end up adding a little more length to the wire in the break spot changing the bend angle a little. I have never had to repair any that I have lengthened (about an inch increase with 1 1/4" piece of wire soldered in). I actually have the two "mystery wires" broken. But since I could not use them with my Clifford alarm (bizarre resistance measured from one plug to the other), they remain unused and broken.
Discussion Starter #11
My service manual indicates that the rear speaker wires are blue-red orange on the right and white blue on the left. They connect to a plug "6P Bu", which I assume is a 6 pin connector where only 4 pins are being used and the connector is either blue or wrapped in blue tape.
2 questions
1. is my assumption correct?
2. where is this connector? inside trunk lid, inside right or left armrest, under seat, other place
2 questions
It’s under the seat at the rear, left side in a boot. They won’t be broken there. They leave there and run up to the left trunk hinge.
It's 6 pin under the seat, but all 6 wires should be used if you have heated seat GL1800, 4 for speakers, 2 for seat back.
1 - 13 of 13 Posts
