Anti-seize and lug nuts
Absolutely a no no. I found out the hard way in my job(before retirement) I managed to break a $900 aluminum pulley because I thought I was smart when assembling with anti-seize. The torque ratings the manufacturers give you are for DRY threads....ask them if you can't believe this. I once read a question and answers column in an RV mag. A gentleman stated that when he was in the military, they used Milk of Magnesia(unflavored) as an anti-seize on an aircraft technical application. The column writer found this hard to believe and contacted the Air Force....sure enough.....they bought large quantities of the unflavored Milk of Magnesia just for this purpose. It apparently acts as an anti-seize only, but not a lubricant. Even if you're lucky enough to not break off a lug nut or something, you're liable to put too much stress on a bearing or gear or bushing or maybe even the rear end housing. There's enough reports on this site of Gold Wing rear end failures, that it makes me wonder how many of these well-intentioned owners may have caused the failure themselves. It could be the shops doing tire installations or other maintenance. The super lubricant properties in anti-seize allow the unwitting well intentioned mechanic to put far more pressure on components than they were designed for. Car manufacturers even caution owners to not put oil on lug nut threads. They don't say why, but I'm fairly positive this is the reason. If you're reading this Fred, what are your comments?
