Like the subject heading says, I’m removing my 2019 gold wing 1800 seat for the first time and I need some help. What is the size of the bolt on either side of the seat? Thanks.
6mm
Sent from my G9 PRO using Tapatalk
It's 6mm and there is a metal washer with each bolt so ensure they are kept with the bolt. Just as important understand you need to disconnect the electrical harness [starboard side] that connects your seat before you lift it off, and secondly know how the seat slides back into place so you don't use force trying to figure it out later..
Many thanks to you both for your help! All went well!
