How hard is it to find one to replace one on a 2002 GL1800 and will other years fit
Others may fit; however, the one you want fits years 2001-03. Usually they're readily available from Honda. Part #12 in the fishe below. What is wrong with yours ???
Before you throw big money at it, makes sure that's really the problem. Check your battery connections make sure their clean and tight. Have the battery load tested.
K.I.S.S. Keep it simple stupid. This is not an insult, it's something to live by.
Rayjoe
Isn't 26 the code for a bad left (right?) knock sensor? Isn't that the one that crops up when the ECM starts to flake out?
Code 26 is for the knock sensor. I had to replace my ECM on my 03. Gerlone said that the error code comes and goes. Before spending the big bucks on a new ECM, do the exchange of the left to right and right to left with the knock sensors. If the error code comes back but it is for the other side sensor it is the sensor that is bad not the ECM.
Unfortunately it is most likely the ECM but I would do the swap to make sure.
