Help! Just replaced the pads, front & rear. Both function very well. However, the fronts are still squeeking after 1000 miles. The rears squeek intermittenly. Did I do something wrong in the installation? Or is there something I can do to stop it?
My independent Gold Wing repair shop also sells stick on anti-squeak pads (which I installed on my stock original pads to eliminate the squeek).Texan said:You may need to spray the back of the pads with a special disc brake coating to stop the squeak. Berryman makes some good stuff, you can probably find it at AutoZone. Take care George
