Fred does a wonderful job.
I can help you some, he will show you and give you the tips and pointers. I remove the two hollow ALOC bolts that secure the rotor onto the wishbone frame. Take care not to damage cables and wires. Pull rotor away. Clean the slave cylinder area before pushing the pistons into the caliper with non marring wedge or brake pad spreader tool. Pry the pads out with brake tool or flat blade screw driver from lower end.
The pad sets are twins, no difference Left or Right, but each individual has a directional orientation as marked. Clean the caliper again. The pads snap into place with firm pressure and are held by spring steel retainers. The ALOC hollow bolts are reusable, but the ALOC anti vibration material may wear off and need to be replaced; I prefer Vibratite VR-2 IIRC the name. Very easy pinless design.
Do buy access to Fred's video series, you will not regret. Much better explanation than mine.
