The switch is good. With the ignition switch off, I push the reverse switch in and turn the ignition on. The reverse light comes on and the actuatur pully turns to the counterclockwise position. When I turn the reverse switch off (release it to the out position), the neutral light comes on, the actuator pully turns to the clockwise position, and the reverse light starts blinking. The bike won't roll so I know the revese is still locked in. When I hit the starter button, at least one starter relay activates with a loud click.
Also, at all times, the headlights are off.
I'm going to look for broken or seriously mis-adjusted cables next.
Any ideas?
Any ideas?
