Hey kids, idling my new to me 03 the fan came on just below the halfway mark on the gauge. Expecting to feel warm air blowing out from the radiator it seemed it was sucking air in. A post it note confirmed it, sucked in against the radiator and fell to the ground when fan shut off. Does this mean my fans are reversed?
Oregonian,
Well Sir, you have to understand the reasoning for Hondas thoughts on this. At very slow/low speeds, as in idling, parking lot, high traffic and stop-and-go stuff, Honda set up the fan direction so the air is drawn in, from the sides, and spit out the front of the bike. In reality, it's normal. You have direct air entering the radiator fins at each side of the bike and then spit out the front, because there's no wind force to counter the direction of the air flow.
And, that part of the design, continues to right at 28 mph. At that speed, Honda has determined that, there now is enough frontal flow of FORCED AIR into and around the forks, that, you now have a natural flow of air. And, at that speed, the fan operation is shut down. Now, the air flow is out from the sides, not INTO the sides, such as low speed.
There were years ago, multiple threads on this subject. And there also used to be, kits that you could buy that actually reversed the flow of the air by using different fan blades, altered fan motors etc. I cannot recall just what the consensus was after the change but, I'm thinking it was positive.
Scott
