Loren,
Not having seen your hands, but reading about them in your earlier posts, I don't think you're
EVER going to be able to get to that connector on an '01 or '02 model. (They were nice enough to extend this connector on the later versions)
The connector has a very short pigtail and is located almost directly behind the mirror so it's very hard to access it. I've installed quite a few connections to that plug for my display timer adapters, and it can be a real bear, and my hands aren't very big.
Your best bet (assuming you don't want to pull the shelter) is to remove the RH mirror - you can usually reach in there to access the plug with the pocket out and the mirror off.
Get the power splitter from Chris that Bulldog mentioned - I think it's long enough to give you enough slack to easily get to the connector. I would
add a connector from E/C to allow you to easily unplug the socket so you can remove the pocket when needed.
This is a fuzzy picture of me touching this connector on my '02 - my fingertips are just on the connector...
When I make the connector for this connection, I make the pigtail long enough to make the connector easily available so I don't have to do this again...
Good luck!
