1 - 20 of 22 Posts
Hi guys. I am having difficulty getting the top rhs shelter off even with a workshop manual. The only video I found on YouTube was Italian and he cheated and cut to a shot of it having been removed.
Does anyone have an online video that might show this?
Thanks in advance
Sent from my SM-G935W8 using Tapatalk
Discussion Starter #2
Thanks in advance
Bump. No one has any videos to share or point me in the right direction? Maybe Covid or maybe me but is there anyone else in this room?
I'm here! I just haven't done it yet. Do you have Fred Harmon's videos? I pretty sure they would show everything you need. I just got my 2017 last August and haven't done much with it yet, but I did recently acquire the 2012-2017 update DVDs.
Thanks in advance
Checkout a Youtube video for an air filter replacement on an FB6. He goes through step by step on how to remove the shelter.
@bobvtx. Did you mean to post something quoting my initial comments as nothing came through..
Administrator
Fred's videos show how to do this. But it's really not difficult. Remove the trim just like you did on the left side, properly mark the bolts as you remove them, remove your center locking 'gizmo', and take your time. But can't stress enough what a life-saver Fred's vids can be.
His response was put inside the quote of your message. If you expand his comments and scroll down you'll see it.
Here it is:
Couldn't agree more.
Discussion Starter #9
Hi guys. I realized I messed up with the title of this. It should have been AIRBAG not ABS. Does anyone know of a video that is for the airbag model?
As an aside I have Fred's videos but after a recent house move I cannot find them.
Apologize for wasting people's time with the non airbag model, I assume it's a different process to release the shelter as I cannot shift it with the airbag in place.
Thanks in advance.
Administrator
Yep, probably makes a difference 👍 How about posting on the tech board? Don't think the 2012 board is read much. Good luck!
ps I can move it over if you'd like......
Discussion Starter #11
Yep, probably makes a difference How about posting on the tech board? Don't think the 2012 board is read much. Good luck!
Yes pls I would appreciate you moving it over for me. Cheers.
Discussion Starter #15
Thanks but this is a non airbag model and I have an airbag and it looks very different to either having a cubby or a cup holder.
Thanks in advance
Bump...
If you have followed the steps listed in the shop manual, the shelter should be loose. I remember the fastener #13 required some fiddling to release. Where specifically are you having trouble?
There are two clips on the lower section of the panel that snap into place, and you have pull fairly hard to get them to release. My suspicion is this is what is giving you trouble. They are located about even with where your ankle would be along the bottom of the panel. You have to get your hand behind the plastic panel and pull straight back. You'll hear a loud snap when they release. When you turn the panel around, you'll see little white clips the fit into rectangular slots. Take a look at the backside of other panel if you already have it off, and you'll see what I'm talking about.
Discussion Starter #18
Hi Fred. Thanks so much. Q. Does the shelter come off without touching the airbag?
Discussion Starter #19
Thanks. Maybe this is what Fred mentioned below your post. Will have a look when I get to the shop.
1 - 20 of 22 Posts
