I need to replace the right handlebar switch on my '02 GL1800. I have a Honda Service manual, but, I can't find where it addresses this. Is there a way to disconnect the throttle cables from the switch assembly without having to disconnect the cables from their lower ends? In other words, how do you unscrew them from the switch assembly once the assembly is separated from the bar and the grip is removed?
