I've read about Satellite receivers that work via an FM modulator. I've also read that the FM modulator attenuates the other FM station's signals.
I would like to find a Satellite receiver that works with the aux input.
Does anyone make one that works with the aux input??
Thanks!
Yes, the Delphi SkiFi XM has an audio out jack that works with the aux audio on the bike. I like it cause it's small and portable. I move it from bike to car and even take it to work with me. I have a car kit installed on the bike which I leave there. I have an extra car kit which I use in the car and take to work for using on the truck I drive there.
Roady
I installed a XM Roady and it works off of the AUX connection. I took my minidisc bracket off since getting XM, there is so much to listen to. I also have my antenna setting on the dash and it picks up fine. They have the Roady at Wal-Mart and you get a free home base for it until Jan. 31.
For a SIRIUS alternative, the Audiovox plug-n-play unit has a cradle with a WIRELESS FM modulator that also has an output for the AUX connection so you can use it in any situation. On the wing I use the AUX, in the truck I use the FM modulator. The best of both.
I love SIRIUS. NO COMMERCIALS.
Paul
The Sirius systems, Audiovox and Kenwood, both use either an FM modulator or the aux connection. With the Audiovox, probably the Kenwood, too, you can turn the FM modulator off when using the aux connection. I don't know about the FM modulator interfering with other FM stations, because I listen to the Sirius system rather than the normal radio. However, I did find that the FM modulator played havoc with my 2-meter portable radio, so I can't have both on in the car, but on the bike and using the aux connections, there's no interference at all.
