I know this is going to seem like a trolling question - I don't intend it to be. I truly seeking to understand the design decisions Honda has made and "why" vs. other manus.
What has me confused power output both in terms of torque and hp. Again, I'm not dumping on the design - it's most likely the very best engine in any motorcycle ever. But, having said that - it's underperforming relative to peers. So, when I give this list of comparisons - I'm sort of trying to learn if getting to the competitor's output would cause a sacrifice somewhere else - other than the obvious MPG.
I am also ignorant as to whether the 125/125 hp/torque ratings are at the wheel or the crank. I'm assuming crank - but, as I mentioned, I'm ignorant.
OK - so, the obvious competitor is the BMW K bike
This bike is rated at 160hp 132 torque. This appears to come in at a slightly higher RPM vs. Honda - but, not miserably off. Assuming the measuring method is similar, 35 hp is huge. Almost 30% higher than Honda. Now, I've been on both of these bikes....and, I like the GW - hands down. I'm just wondering why they can't get closer within the existing engine design.
If you compare the other BMW that "sort of" works - you can look at the R (or GS) model.
These bikes are only 1250cc displacement and put out 136hp and 105 ft/lbs of torque. I know they are only 2 cylinders, but I would assume more revs are "easier" to design with more cylinders. While the torque number is lower overall - the torque per displacement is better on this BMW.
Anyway - none of this is changing my mind on loving the GW. Perhaps the rider community really prefers MPG to power and folks believe there is "enough".
I know I don't use all the power all the time in my bike....so, much of this is a marketing exercise. Perhaps GW riders are just sophisticated enough to disregard the spec sheet.
