1 - 1 of 1 Posts
You can buy helmet lock extensions for about $18 delivered. Some are specific for Shoei but say they will NOT work on Nolan. Guess it must be vice versa, too. Got several good ideas from others here, including making a extension from a piece of aluminum, and using a “T” piece of flat steel such as you’d find on a weak screen door. I found something
367570
even easier.
Use a small drawer brace or bracket such as sold under the “National” brand at the hardware store. I used the 3” nominal size. Cut off one side between the 2 holes. Done. $2 unless you already had this laying around!
This is great for helmets with the ratcheting quick closures. If you have the lower-tech D-ring closures, use the “T” piece of hardware already mentioned.
367569
Reactions: laen
1 - 1 of 1 Posts
