Here we go. First off, I applaud you for going darkside, however....I have a question... Does any tire manufacturer make run flat tires for Motorcycles? The answer is absolutely not. No, nada, zilch. Why do you think that is? Oh that's right, you're not supposed to ride on a flat tire. So once again, someone is living in fear and following the herd. Thinking a run flat tire is better than a none run flat. Guess what? It's not. I've rode tens upon tens of thousands of miles on a regular darkside car tire. Even had flats. I plugged it and kept right on rolling. I just installed a Goodyear assurance maxlife on my 2021 GW DCT tour. 205/55/16. $95. Works great.
Well Sir,
I myself don't think you're putting out any "BS" in this post. I've only owned my '18 GL1800 DCT Tour Airbag now for about 2 months and have put on it, about 3,000 miles, plus or minus. I ran C/T's on my previous two GL1800's without any issues and they were NOT RUN FLATS. I got around 22,000 miles on the first one and around 23,000 miles on the second one. Both still had tread left on them when I replaced them.
Well, when it came time to replace the rear tire on my present '18 Tour, I decided to go dark side on it too. Well, like you stated, I also stated the same thing, I've never, ever seen a RUN FLAT motorcycle tire. So, I made the same decision on this bike that I did several years ago and that was to pursuit a standard non-run-flat tire. The folks on here have their reasons for everyone going for the same tire(s) when it comes to C/T's for their bike.
I myself simply look for a tire that's as equal to the size of the original rear tire. I determined that a basic 205 55 16 was what I wanted. I went to my local Discount tire and they would not touch my rear rim and tire 'cause it was a motorcycle tire. So, I went to an independent tire shop and asked if they'd handle it. The two techs came out, looked at my rear Wing rim and worn tire and said: "Yep, we can handle this, no problem." So, I went into the office and asked what they had in 205 55 16's. They had two different brands. I looked at both and picked the one I thought would work.
They dismounted my worn tire and installed that new one in about 2-3 minutes. It cost me about $110 out the door, mounted with no balance. They stated their balance machine could not mount my Wing rim due to the hole in the center was too small for the cones on their machine. So, I went home with my new tire and wheel and balanced it myself with my Harbor Freight balancer.
That non-run flat has been on there now for oh, maybe a month and it has around 1,500 miles on it. It handles like a dream, just like my other Wings. So, if one wants a run flat due to they think it's more security, then have at it. There was no run flat on the bike when they bought it.
Scott
