i dropped a nut into the engine area while changing my air filter. Took the airbox off to expose the throttle body and top of engine. Moved wires around a bit while looking for lost nut. Found it, put bike back together and now three things have happened. 1. The radiator fans won't come on while idling and coolant gets over normal running temperature. 2. when riding the bike, for no reason, the gauges all go to zero on the dash, the dash lights go out and the tail lights go out. It burns out the 20 amp fuse for meter/illumination. 3. for no reason the engine will start missing, running very rough, and will barely idle at 300 rpm and then for no reason will start running properly again. I took the bike apart again to see if any connectors were loose or unplugged under the airbox. Everything looks perfectly fine. I can't find the problems. I cant make any of these problems happen by wiggling wires, etc. I need some guidance. Any help would be appreciated. Thanks, Dave
