1 - 9 of 9 Posts
2006 wing, when it was new put a Kury side stand on it which made it look good and it has worked fine (20K later) ever since. today I was checking the bike out for a trip on the center stand and having nothing better to do I put the side stand down and found that it had some play in it when I pulled it back and forth (90 degrees from the bike.) I have a full sized SO that has to mount by standing on the peg and going leg over. The stand may have been this way since new but I never tried to check it this way before. My question(finally) is this slack normal and have any of you ever had a side stand failure ? Thanks gene
You can put a shim, (thin washer), in the stand slot and remove a lot of the slack. I have the Duck Foot kickstand shimmed and there is virtually no play. My wife also needs to mount with the bike on the kickstand.
Trev.
+1 on the shim.
I made a very thin shim from a brass washer.
Took care of the shim.
Swings freely but no thump when the bike comes onto the stand.
New ones have virtually NO side slop
(I have a bucket full of them from NEW trike take off's.)
My wife gets on with the sidestand down too
and I'm on my third one
(sidestand, not wife).
I think how fast they get sloppy depends
on weight applied and dirt/sand "grinding factor"
... pretty sandy down here in Florida.
You can pick up a new stock stand pretty cheap.
Usually includes the stand, bolts, back plate and springs
as a unit ...
everything "new" again.
Dennis
A little chain lube (foaming type) can keep the joint lubricated. Will help lengthen it's life. Mine had some slop in it brand new so I think they make them loose on purpose.
Same with my side stand
I just installed the Baker "Ride Off/On" stand....wonder why I waitied to do so!!
Getting on/off with the wife is much, much easier....one of the top 5 add-ons I have purchased for the Wing
Good point on the lube.
Don't be afraid to take the side stand off every now and again so you can give the pivot a good cleaning and get 'er greased up proper.
1 - 9 of 9 Posts
