1 - 3 of 3 Posts
Put new tires on yesterday. Noticed pressure low today. I have a slow leak around the rim in one place. How can I fix it without taking wheel off or can I? Thanks for the help
Brian T. in Tn.
Most likely there is a bit or dirt or other matter that got between the rim
and the bead. I would guess that the area would need to be cleaned and
the tire would need to be re-seated at minimum. Could also be a bum
tire, but would hope for debris :)
As stupid as this sounds, get a mallet and hit the tire where it's leaking a few times. You can try hitting the tire on the crown and/or the sidewall. You should be fine. Remember to always check the balance yourself as the tire guys tend to do the minimum.
1 - 3 of 3 Posts
