1 - 8 of 8 Posts
How many speed bleeders would I need for a full set on a '10 ABS? Does the bike use the same bleeder throughout? How much does a full set run and where is a good place to get them?
Johnny S
8! Six on the brakes, 0ne for the anti dive, and one for the clutch.
Shinhopples has the correct ones, the model L type that fit easily at all 8 locations. There may be little, if any, real need to use the Speed Bleeder at the clutch location because that one will gravity bleed since the bleeder is at such a low point in the system. The model LL Speed Bleeder will not fit at the clutch location due to the EVAP canister bracket and the LL version is a very tight fit at upper right brake. Make sure you the L version, which is all Shinhopples is supplying.
Installed mine yesterday and bled brakes. I bleed about every 40k+-. Sure made bleeding easy. Murphs, $7 each free shipping. Got them in 3 days.
1 - 8 of 8 Posts
