OK Smart guys…need a little help here before I act. I did a search on the forum about this but no real answer was given after similar complaints. Recently I’ve had a strong fuel smell come from my bike after I shut it down in the garage. It doesn’t happen all the time and when it does the smell goes away after I leave the garage door open. I have not filled up the gas tank too much or forgot my gas cap at the fuel pump (beat you to it.)
I do fill up after my rides though. There’s no visible gas leak and I suspect if there was the fuel smell would remain. The only answer I found was to replace the fuel cap and that the Evap charcoal canister might be saturated with fuel. What can I do to purge this canister if it is saturated? Is that caused by operating at a too low RPM? :shrug:
