1 - 4 of 4 Posts
Anyone know where to access switched power under the seat? One that only energizes when powered on and dies when the bike is shut off?
There are accessory terminals located in the fues box for this purpose. They are labeled as such, there is a screw terminals for both Positive and Negative. I hope this helps. It is not advised to tap wires anywhere else without adding an isolated fuse block for risking damage the CanBus System
Its the top left on the fuse panel, good for small loads like a GPS, otherwise as said, put a relay on it if you want to power bigger stuff like lights.
Discussion Starter #4 (Edited)
Thanks all.
I was previously trying to hook up my Owl camera but the vendor is not willing to assist with wiring requirements. I was needing to know if they needed a L-Line or K-Line connection through the DLC on the bike to the OBD from their camera for monitoring the battery status.
So I am thinking of buying the Innovv K2 but it requires a steady 12v and a switched power also. I just wasn't sure about the switching part but your replies helped me.
1 - 4 of 4 Posts
